How to generate random code with limited range
selece28selece28 Member Posts: 316
edited 2012-10-03 in NAV Tips & Tricks
Hi Nav Masters
I have a problems, i need to generate 8 digit Code which each digit is random code consist of : number 2 to 9 (without 0 and 1) or A to Z or a to z
Can we do this?
How to do it in navision c/al code?
Thanks in advance,
______________
Steven
    RandomDigit is of type text. length 50
    RandomDigit := CREATEGUID;
    RandomDigit := DELCHr(RandomDigit,'=','{}-01');
    RandomDigit := copystr(RandomDigit,1,8);
    Message(RandomDigit)
    You can also use
    randomize;
    RandomDigit := format(random(7)+2);
    but the problem is that randomize needs a seed that is unique every time you call it.
    otherwise it uses system time, and so if you call more than once within a second it will return the same value.
    Hi Rashed,
    Thanks for the reply.
    I think the 1st one is great, but what is the : CREATEGUID used for?
    I don't understand, can you explain a little?
    Ow and one more, random cannot randomize char right?
    ______________
    Steven
    =D> cool idea.
    David Singleton
    kinekine Member Posts: 12,562
    selece28 wrote:
    Hi Rashed,
    CRATEGUID is generating GUID which is "Globally Unique Identifier". You can google more about that. It is some "code" which you can use as unique, because the chance, that somebody will generate same GUID on the planet is small. It means that the GUID is "random" and the code use this to generate random data and taking some character from the result as random...
    Char is just number presented as text. And because you can convert number to char and back, you can "randomize" char... Just random integer and assign it into Char variable...
    [Topic moved from Navision forum to Navision Tips & Tricks forum]
    mabl4367mabl4367 Member Posts: 143
    If you use the GIUD sugestion you may get unlucky and get a string with less then 8 characters if the GIUD generated containes less then 8 valid characters.
    Instead create a character array that holds all the valid characters. Then generate 8 radom numbers between 1 and the length of the array and add the corresponding array element to your codestring.
    validChar[1]:='2';
    validChar[2]:='3';
    validChar[7]:='9';
    validChar[8]:='a';
    validChar[9]:='b';
    validChar[32]:='z';
    validChar[33]:='A';
    validChar[34]:='B';
    validChar[57]:='Z';
    codeString:='';
    RANDOMIZE();
    WHILE STRLENGTH(codeString)<8 DO BEGIN
      codeString:=codeString+validChar[RANDOM(57)];
