Object Manager Advanced v10.03 (trial till 15-11-2017)
1678911
    AkedrenAkedren Member Posts: 1
    Hi, this looks like a really great product I am just having some trouble with the Trial version on my machine.
    I am using an SQL 2008 R2 Express Backed installation of Microsoft Dynamics NAV 200 R2, following the initalization instructions once I get to the 'Update C/AL History' step I keep getting an error message.
    When attempting to update C/AL History or Export Object -> Export as Text I get the generic error message. Checking the Temp working directory I notice that the export file is successfully created.
    If I use one of the alternate methods of exporting objects such as exporting to a specific version I get a different error message, "String was not recognized as a valid TimeSpan".
    I do have a valid developer license and I am able to export to text directly from object designer, which are able to be imported. When I import these objects I note that the C/AL History does not seem to update. I am running as an administrator, and have attempted it on two different computers, both running Windows 7.
    Thanks for making such an interesting product, I look forward to being able to try out some of the features that depend on the 'C/AL History'
    Object Manager Advanced v8.5.2 (trial till 15-12-2012)
    Click here to get a sneak peak at the all new Object Manager Advanced 2013!
    Over 600 Companies worldwide already have chosen for the Object Manager Advanced for their development, source control and deployment, and now there is a new version. Version 8.5 is an immense upgrade of the product. More than 100 enhancements were made in this version, including a much improved translation tool. You can find the complete listing of changes and new functionality on our website.
    Dynamics NAV 2013
    The Object Manager Advanced will be available in Dynamics NAV 2013. Of course, all of the partners and customers who already bought the Object Manager Advanced will receive this new version. You can find a page dedicated to NAV 2013 here: OMA 9 for NAV 2013.
    The Object Manager Advanced – Save Money & Time
    The Object Manager Advanced is the most comprehensive product for development and deployment for Dynamics NAV. The quality and continuity are recognized by Mibuso ("Best Download Award") as well as Microsoft ("Microsoft Innovation Award 2010"). IDYN also became member of the prestigious "2012 Microsoft President's Club". The Object Manager Advanced is the best tool for supporting your developers and consultants in Microsoft Dynamics Sure Step or any other methodology tools in place. Using the Object Manager Advanced will not only help you develop in Microsoft Dynamics NAV, it will also reduce time and costs when it comes to maintaining your solution and deploying it to your customer. The newest version of our award winning tool, is packed with new features as well as enhancements on existing functionality. The Object Manager Advanced let customers use the Role Tailored user interface to import new objects, actions, data and/or roles.
    Develop
    The Object Manager Advanced reinvented the development environment in Dynamics NAV. Working in projects, with multiple developers at the same time in the same environment, streamlines the way developers and/or development teams deliver their solutions. Source Control and Version Control are built into you NAV environment. Powerful tools with functionality such as the ability to lock objects, save objects in a repository like VSS or TFS, renumber objects, fields and elements without hassle and the addition of a project module, will help lower time and costs with a higher quality of work. Whether you are working on a new add-on, upgrade existing solutions or if you're just making some customizations, the Object Manager Advanced will help you accomplish you goal faster against lowers costs and higher quality.
    Click here for an overview of the Develop tools
    Analyze
    The power of the Object Manager Advanced is completely unveiled when you start analyzing your or other people's code. Errors and conflicts are easily found and fixed, and you won't even have to be familiar with the solution you're working on. The Where-Used functionality enables you to check where objects, fields, triggers, etc. are used. The Check Guidelines tool will not only check if the guidelines requirements are met, it even has the possibility to correct guidelines errors in C/AL code, whether you want to use the standard Microsoft guidelines or your own.
    Click here for an overview of the Analyze tools
    Deploy
    Deploying your solutions and updates to your customers can be a time consuming exercise. When using the Object Manager Advanced at customers, the days of endless checking, testing and comparing are gone. Combine all modifications in a transport and use the wizard to import them into your customer database. Using the highly improved and extended version of the Fob file, will allow you to send application settings, roles and documentation together with your objects. Your customers will have an much greater insight of the work and changes you've made. Deploying with Dynamics NAV never was this easy and reliable, resulting in more satisfied consultants and customers.
    Click here for an overview of the Deploy tools
    Click here for an complete set of demo videos of the Object Manager Advanced functionality
    "Just started using Advanced Object Manager and it's absolutely amazing. I wish I knew about this product before. Congratulations this product is a MUST for any NAV developer."
    Emmanuel Talbot, Navision Development Supervisor, Department of Information Technology, Kitco Inc., USA
    "The Object Manager tool increases my programming productivity enormously and helps me saving time. That makes Object Manager Advanced a wonderful Add-On, I wouldn't want to work without it anymore"
    Michael Peters, IT Department BOS FOOD, Düsseldorf, Germany
    "If you see it, you want it – If you have it, you want to keep it"
    Timo Lässer, msdynamics.de, Germany
    “This is the best development tool for Dynamics NAV available in the market. We are very happy with our choice and our development team loves to work with it.”
    Rebecca Yih, TrendMicro Taiwan
    http://www.mibuso.com/dlinfo.asp?FileID=826
    OrionovOrionov Member Posts: 1
    I am having the same issue with the paid version of the product. I did not have this problem with the trial.
    I can not update C/AL History because I am unable to export objects as text via the Object Explorer. I can do it fine through the native Object Designer... I do have a developers license as well...
    AdunAdun Member Posts: 19
    I am trying to install the trial version, but the error pops up while executing "Object Manager Setup 5.0.1.exe" after i push "Instal" in the setup and the proccess bar jumps at about 70%.
    It say "IDYN.Utils.Register.ComComponent" "stopped working"
    Problem signature:
      Problem event name:	CLR20r3
      Problem signature 01:	idyn.utils.register.comcomponent
      Problem signature 02:	1.0.0.3
      Problem signature 03:	4f4b4d8d
      Problem signature 04:	System
      Problem signature 05:	2.0.0.0
      Problem signature 06:	4a275e12
      Problem signature 07:	3a98
      Problem signature 08:	288
      Problem signature 09:	System.ComponentModel.Win32
      OS version:		6.1.7600.2.0.0.256.4
      Language Code:		1049
    Any idea how to fix this issue? :)
    geordiegeordie Member Posts: 655
    Will be the trial period extended?
    reijermolenaarreijermolenaar Member Posts: 256
    Yes, the trial will be extended.
    Reijer Molenaar
    Object Manager
    Ok thanks :wink:
    ringertringert Member Posts: 4
    we have the Advanced v9.00 BETA Version.
    We have a lot of problems with the file management in NAV2013 with OMA9. When there is a newer version of OMA9?
    Can you please send a brief description of your problems to support@idyn.nl.
    Then we can see it we already solved these issues.
    Thanks!
    Reijer Molenaar
    Object Manager
    Object Manager Advanced v8.5.3 (trial till 15-03-2013)
    Dynamics NAV 2013
    Develop
    Analyze
    Deploy
    Object Manager Advanced v8.5.3 (trial till 15-05-2013)
    Dynamics NAV 2013
    Develop
    Analyze
    Deploy
    ebsoftebsoft Member Posts: 81
    I got this error when opening the OM - Setup card.
    I confirm you that I installed the "OMA8.5.3 NAV2009 R2 trial till 2013-05-15.fob" onto our db.
    Can you help please?
    Federico
    MBS Specialist since NAV 2.0
    My experiences on Linkedin
    The OMA checks if there is an object with the a modify date after the trial period.
    Do you have an object with a date greater than 15-5?
    Reijer Molenaar
    Object Manager
    Nope I don't have!
    That's strange... on a Cronus DB it works, but not on our DB.
    Federico
    GertieGertie Member Posts: 1
    Is there a possibility to also check the Options?
    Because in the Object Manager they are not shown as a Calculated Caption.
    This would be a nice feature for all developers (and translators).
    You can set all the captions right except for the Options.
    Kind regards,
    Gertie
    Hi Gertie,
    You're right, the translation of options is not working anymore.
    Same for the tab names.
    We will fix it in the next release!
    Thanks for mentioning it!
    Reijer Molenaar
    Object Manager
    Object Manager Advanced v8.5.4 (trial till 15-07-2013)
    Dynamics NAV 2013
    Develop
    Analyze
    Deploy
    Object Manager Advanced v8.5.4 (trial till 15-09-2013)
    Dynamics NAV 2013
    Develop
    Analyze
    Deploy
    Object Manager Advanced v8.5.4 (trial till 15-11-2013)
    Dynamics NAV 2013
    Develop
    Analyze
    Deploy
    Johannes_NielsenJohannes_Nielsen Member Posts: 206
    So, any news on when we can expect the 9 / 2013 version released?
    Best regards / Venlig hilsen
    Johannes Sebastian
    MB7-840,MB7-841
    mknevelmknevel Member Posts: 11
    Hi Johannes,
    Can you send me a PM with your mail address (or send one to sales@idyn.nl)? I can send you a download link for the 2013 and 2013 R2 versions.
    Visit www.idyn.nl for more information and news about the Object Manager Advanced, ConnectIT, E-Invoice and our other great products.
    kjboloekjboloe Member Posts: 56
    Is there a install manual for 2013 R2.
    I am trying to setup the Object Manager in a NAV 2013 R2 development enviroment.
    When I try to update the History, I get an error that it can't find the File ](*,).
    I have debugged and found out, that in codeunit 11102046, in the function ExecuteCommand it fails when trying to process the Command.
    'ExportObjects ....file=D:\OMA\Page 5008.txt, filter="Type=Page;ID=50008"........
    In out eviroment we have 2 servers :
    - SQL server
    - Development server
    The NAV server service runs using a user "nstsvc"
    This user has DBOwner permissions for the NAV database
    I have DBOwner permissionss for the NAV database
    What can be wrong ?
    Kind regards
    Kenneth Jarlshøi Bolø
    Dynateam A/S
    Hi Kenneth,
    What results do you get when you run the "Check Settings" option in the administration tasks?
    Reijer Molenaar
    Object Manager
    Hi, I have solved the problem, so I am a happy camper \:D/
    Kind regards
    Dynateam A/S
    Object Manager Advanced v9.0.2 (trial till 15-01-2014)
    Over 750 Companies worldwide already have chosen for the Object Manager Advanced for their development, source control and deployment. The Object Manager Advanced is available from NAV version 3.70 up to 2013R2.
    Dynamics NAV 2013 R2
    The Object Manager Advanced is available for Dynamics NAV 2013 and 2013R2. Although we don’t have a demo version for these NAV versions, we can offer you a (online) demo session with one of our experienced consultants. Just send an e-mail to sales@idyn.nl, and we will plan the demo at a date and time that is convenient for you
    Develop
    Analyze
    The power of the Object Manager Advanced is completely unveiled when you start analyzing your or other people's code. Errors and conflicts are easily found and fixed, and you won't even have to be familiar with the solution you're working on. Comparing different databases is easier than ever. The Where-Used functionality enables you to check where objects, fields, triggers, etc. are used. The Check Guidelines tool will not only check if the guidelines requirements are met, it even has the possibility to correct guidelines errors in C/AL code, whether you want to use the standard Microsoft guidelines or your own.
    Deploy
    jonwlongjonwlong Member Posts: 11
    Having the same issue kjboloe had. ](*,) kjboloe, how did you solve it? Here's the results of the "Check Settings". My Working Dir F:\Temp. I tested with multiple working dir's and security settings. I also debugged and it seems to be looping endlessly when moving the test file to the working dir. Version Advanced 9.02 (RC 2013-11-01)
    Error Start..........................................
    General Settings: Ok
    File Settings: Ok
    Database Settings: Ok
    Object Management Settings: Failed
    Error: Command Line Failure:
    No result file.\\Possible reasons:\1. Wrong "Working Directory"\2. The license is about to expire.
    Version: Advanced 9.02 (RC 2013-11-01)
    Call Stack:
    "OM - Object Management"(CodeUnit 11102046).ExecuteCommand line 44
    "OM - Object Management"(CodeUnit 11102046).ImportObject line 15
    "OM - Check Settings"(CodeUnit 11102064).TestObjectManagementSettings line 33
    "OM - Check Settings"(CodeUnit 11102064).OnRun(Trigger) line 50
    "OM - Check Settings"(CodeUnit 11102064).OnRun(Trigger) line 10
    "OM - Administration Tasks"(CodeUnit 11102085).CheckSettings line 1
    "OM - Administration Tasks"(CodeUnit 11102085).OnRun(Trigger) line 8
    "OM - Administration Tasks"(Page 11102132)."<Action2> - OnAction"(Trigger) line 1
    Triggers: Skipped
    Cause: There was an error in a preceding check.
    OK
    Error end............................
    Jon Long - ArcherPoint
    MCP - Dynamics NAV
    Hi Jon
    My problem was that the NAV client was installed on the D drive, so when I changed the location of the Client everything works fine :-)
    I checked the SQL database, to insure that I was a DB Owner for the NAV Database.
    Hope that you will get it to work, it is an amazing product \:D/ \:D/ \:D/ \:D/ \:D/ \:D/
    Have a nice weekend 8)
    Kind regards
    Dynateam A/S
    Object Manager Advanced v9.0.2 (trial till 28-02-2014)
    Develop
    Analyze
    Deploy
    Kenneth
    Issue still not resolved.
    I have NAV installed on the C drive. I've tried various locations for the working dir including the default and still having the issue. This issue is only on one machine. I've installed it on several other machines without failure.
    MCP - Dynamics NAV
    Hi Jon,
    This is a hard part to find out what’s wrong. The OMA uses the command line feature to import an object in text format.
    (let’s all pray that the IMPORT- and EXPORTOBJECTS commands are coming back in the next release!!)
    It’s the following piece of code in codeunit 11102046 - OM - Object Management:
    Process := Process.Start(Setup."Compiler (Finsql on Server)", Command);
    Process.WaitForExit(5000);
    IF NOT FilePresent(ResultFile) THEN BEGIN
      ErrorOccured := TRUE;
      LastError := ctNoResultFile;
    The result file is not created in your case, but why? The only way to find out is to open a RDP on the service tier and do the same command in a DOS box…
    If you need help with this, our support desk will be happy to assist you. support@idyn.nl
    (or ask your follow up question here)
    BR,
    Reijer
    Reijer Molenaar
    Object Manager
