Kill Idle Navision Sessions (SQL scripts)
This is a modification of the TSQL script from Steve Jones -
www.dkranch.net I use since several years.
This new version kills only programs with "Navision" in their name and warn users with a "net send" message.
This archive contain a SQL Server job which run the script once per minute and kills idle sessions for more than 30 minutes.
http://www.mibuso.com/dlinfo.asp?FileID=367
1.) Add job to SQL Agent. (Job sp_KillIdleSpids.sql)
- To install it, you need to start SQL Server Agent, and change the databasename in the script into your database name. Execute it in SQL Query Analyzer.
- According to the script, it will actually schedule to run the script to perform checking every minutes between 8am to 6pm.
- The task is stored in msdb database in tables(sysjobs, sysjobschedules, sysjobservers, and sysjobsteps)
2.) Create store procedure. (sp_KillIdleSpids.sql)
- This store procedure will be trigger by the job above, to kill the user from the database and net send message to their screen.
I hope this helps.
Peter Ng
I solved this problem by above solusion
Here, compile location is important.
sp_KillIdleSpids.sql ==> master database
Job sp_KillIdleSpids ==> msdb database
8) 8) 8)
But another problem is ....
"Net Send ..." does not execute...
Why not ??? ](*,) ](*,) ](*,)
※ Win2K Server, SQL Server 2K, Navision 4.0
RIS Plus, LLC
MVP - Business Apps
Thanks for the reply though.
RIS Plus, LLC
MVP - Business Apps
The script I got does the same thing as the 'Sessions' view. Thanks anyway.
set @cmd='msg ' + ltrim(rtrim(@username)) + ' /SERVER:' + ltrim(rtrim(@hostname)) + ' ' + @msg
You also need to add new variable @username and take value from nt_username like this:
declare u_curs scroll insensitive cursor for
select s.spid, s.hostname, s.nt_username
from master..sysprocesses s
where s.program_name LIKE '%Navision%'
and (datediff( ss, s.last_batch, getdate()) > @sec)
open u_curs
fetch next from u_curs into @spid, @hostname, @username
I have set the scripts onto an environment having SQL 2005 & Nav2009
The issue is that when the sql scripts run, when one views file > database > information > sessions the idle users are correctly removed from the list.
BUT
i) The user does not receive a message indicating that he has been killed
ii) The user can continue using navision not needing to login again.
kindly advise
D
I try to implement this example on my PC ( SQL Server 2008 + Windows 7) and try with Dynamics NAV 5.0 SP1 but so far it didn´t work.
Below i describe the steps for implemeting this Scripts on SQL:
1.) Add job to SQL Agent. (Job sp_KillIdleSpids.sql) - To install it, you need to start SQL Server Agent, and change the databasename in the script into your database name.
@database_name = N'Demo Database (5-0) -> Here i pointing this step into my Database ->Demo Database (5-0), but i dont have sure because ranian92 refers to msdb database .QUESTION: HERE TO Point THIS JOB? AND I CHANGE THE TIME TO 60 seconds
2.) Execute it in SQL Query Analyzer.
I EXECUTED AND THE COMAND WORKS WITHOUT ERRORS
3.) Create store procedure. (sp_KillIdleSpids.sql)
WHERE TO CREATE THE STORE PROCEDURE? ON MY DATABASE OR ON THE MASTER DATABASE like ranian92 refers?
LAST QUESTION: How to test. I go to Dynamics NAV > Database Information -> Sessions ->and i try to see if the inactive time for a session is greater than 1 minute. But the time is constantly moving and the number of licences do not decrease.
I have same result... Can anyone tell us how we should test? or what is wrong?
as said the scripts should be executed as these way:
Job sp_KillIdleSpids.sql -> msdb
sp_KillIdleSpids.sql -> master
and then in sp_KillIdleSpids.sql in these part you need to change the value %Navision% to something %nav% cause the program_name is running under "Microsoft Dynamics NAV client" something like that so it will select nothing.
After this you need to enable xp_cmdshell. In order to do that you need to go to SQL Surface Area Configuration and enable it.
To enable the netsend you need to start the service.
thats all folks
Specified SQL Scripts are running successfully in my SQL Server without any error.
I have modified Program Name filter to '%Dynamics%'.
But, My NAV Classic and RTC are not going to close on end user PC.
What can be the issue?
Please, help me.
Ahmedabad, Gujarat, India
E Mail : ravi.thakkar@hotmail.com
Don't exist a cursor named 'U_curs'. [SQLSTATE 34000] (Error 16916). The step failed.
Someone can help me?
I wrote something in NAV Codeunit 1 that kills the sessions. Except that it only works on a native database.
In SQL it deletes the entry from the Session table, and you can see it is gone, but as soon as the user opens a form the session is back again.
So I downloaded this, implemented it and the same result!
Session entry is removed, but when you click on a menu item or navigate through records a new session entry is created with a new session ID. :?:
Ewald Venter
I have sql 2005 and I have the same problem like sunil_knd, the job return me this error:
A cursor with the name 'U_curs' doesn't exist. [SQLSTATE 34000] (Error 16916). The step failed.
What could be the cause for such a problem?
Regards.
I fixed the problem. Actually it was something simple but ... Anyway, the problem was that in fact a cursor with the name 'U_curs' doesn't exist!!! It exists but not with capital letter. I changed the capital 'U_curs' to 'u_curs' in the file sp_KillIdleSpids.sql at line ... deallocate U_curs and this error message doesn't appear any more.
Regards.
Dear All,
I Have same problem too. But SQL 2008 & Nav2009 R2
iii) New user can login If Old Users continue using navision then overflow the licence
How to fix this issue pls kindly advise
"I Have same problem too. But SQL 2008 & Nav2009 R2
iii) New user can login If Old Users continue using navision then overflow the licence"
I have disabled this until I figure out what exactly is going on.
Has anyone experience this as well?
if exists (select * from dbo.sysobjects where id = object_id(N'[dbo].[sp_KillIdleSpids]') and
OBJECTPROPERTY(id, N'IsProcedure') = 1)
drop procedure [dbo].[sp_KillIdleSpids]
go
create procedure [dbo].[sp_KillIdleSpids]
as
declare
--@sec int=null,
--@diff int,
@spid int,
@cmd char(255),
@loopcount int
set @loopcount=( select count(s.spid) as count1 from master..sysprocesses s
where program_name LIKE '%NAV%'
and ((select DATEDIFF(SS,s.last_batch,GETDATE()))>180) ) --180 stands for 3 minutes
while @loopcount!=0
begin
set @spid=(select top 1 s.spid
from master..sysprocesses s where program_name LIKE '%NAV%'
and ((select DATEDIFF(SS,s.last_batch,GETDATE()))>1))
set @cmd=convert(char(4), @spid)
exec( 'kill ' +@cmd);
SET @loopcount =@loopcount-1
end
Create the SQL JOB
define in step
exec sp_KillIdleSpids
