Background color in Navision?
tentacletentacle Member Posts: 27
is it possible to change the background color of Navision from grey to any other color? (Edit: we are running 4.03)
We have 2 Navision Databases (one live and one dev) just before the go-live. The only difference between those databases is the small ending -DEV in one of them. I want to avoid that any user thinks he uses the DEV database and plays around with the 'real' data. So some red color might help!?
  • Timo_LässerTimo_Lässer Member Posts: 481
    We use a very small Form which we will run from Codeunit 1.
    This Form appears always in the upper left corner and shows the Database-Name.
    In OnFormat, we change the color of the textbox, so everybody can see, if he/she is on the "Live db", "Test DB" or in "Dev DB".
    As you come from germany, you can have a look at this discussion: http://www.msdynamics.de/ftopic1367.html
    Timo Lässer
  • WaldoWaldo Member Posts: 3,412
    I posted a solutions some time ago in this thread:
    http://www.mibuso.com/forum/viewtopic.php?t=14824
    Eric Wauters
    MVP - Microsoft Dynamics NAV
    My blog
  • tentacletentacle Member Posts: 27
    This is a very good idea Waldo.
    So I need to get the database name in Navision. Somebody wrote in the download section should be some code for it but unfortunately I can not find it?
    Company name seems to be easy but what about database name?
  • geri79geri79 Member Posts: 105
    I use this in CodeUnit and call it an form similar as discribed above:
    dbname() sret : Text[1000]
    i:=STRPOS(name,'database=');
    IF i > 0 THEN BEGIN
    i:=STRPOS(name,'&');
    dbname:=COPYSTR(name,1,i-1);
    sret:=dbname;
    PS: I found it once in the forum...
    geri
  • ArhontisArhontis Member Posts: 667
    Example of getting the db name, the server you are connected to, the userid and the computer name you are connecting with..
    Name	DataType	Subtype	Length
    vSession	Record	Session
    vServer	Record	Server
    ServerName	Text		150
    DatabaseName	Text		150
    OtherInfo	Text		150
    DatabaseName := '';
    OtherInfo :=  '';
    ServerName := '';
    vSession.SETRANGE("My Session", vSession."My Session"::"1");
    IF vSession.FIND('-') THEN BEGIN
      DatabaseName :=vSession."Database Name";
      OtherInfo := vSession."User ID"  +'-PC:'+vSession."Host Name";
    vServer.SETRANGE("My Server", vServer."My Server"::"1");
    IF vServer.FIND('-') THEN
      ServerName := vServer."Server Name";
    thanks, works very fine!
  • PhennoPhenno Member Posts: 630
    You have to be carefull with this solution. If you're on Native DB, record "server" (virtual table actually) doesn't exists at all so you'll not be able to, even, compile the form.
    Server table works only on SQL server versions...
    You are absolutely right Phenno...
    Thanks for reporting it... Forgot to mention it... :oops:
