It is currently Sun May 19, 2013 8:03 am
Post new topic Reply to topic  [ 3 posts ]
 Post subject: GnuPG Navision Interface
PostPosted: Sun Oct 12, 2003 12:31 pm
Site Admin
Country: Belgium (be)
GnuPG Navision Interface for Navision in order to be able to automatically encrypt files that were created in Navision.
http://www.mibuso.com/dlinfo.asp?FileID=302
 Profile
 Post subject: Re: GnuPG Navision Interface
PostPosted: Thu Jun 23, 2011 12:53 pm
Country: Finland (fi)
Hello all
I have been trying to make this work with my customer's NAV 2009 R2, but so far with little luck.
I have managed to find out that the first error (Ungültiger Dateiname) referred to the fact that I had to map F:\ to somewhere, since the ocx writes a log file always to this location.
However, then the problems started. I seem to be unable to encrypt anything at all.
I have been using functions GnuPg.SetGnuPGFilePath for correct pgp.exe path, but i am unsure if this should contain both the program name and path, or just path.
Probably it needs both, since if I use function GnuPg.enumPublicKeys -function, i receive error if there is pgp.exe, but no error if there is only path.
Error is: Der Index der Liste überschreitet das Maximum (5)
Also, function GnuPg.encryptFile(KeyID, fromfile, tofile) does not seem to work. It writes log file to mapped F:\ disk, but that doesnt help me much.
Anyone know the right syntax for KeyID? Should it be e-mail address or the key I have in my GNU Privacy Assistant key manager?
Unfortunately it is very long time when I last used Delphi or Pascal, so it is very hard for me to read the source file, and I do not have Delphi compiler, so I cannot do modifications to the OCX either.
Please, anyone?
_________________
"There is no spoon."
--Matrix
 Profile
PostPosted: Mon Jan 28, 2013 10:03 pm
Did u ever get this to PGP encryption to work? Or find another option?
 Profile E-mail
Users browsing this forum: No registered users and 3 guests
