Print the Total Page Number
edited 2009-02-27 in Download section
small trick to print the total page number
This fob file is uploaded as support for the thread Display page no in format PageNo / TotalPage Simple trick.
Objects are Form 80000 & Report 80000.
http://www.mibuso.com/dlinfo.asp?FileID=962
    MtamimiiMtamimii Member Posts: 7
    OBJECT Form 80000 GetPageNoTest
      OBJECT-PROPERTIES
        Date=05/31/08;
        Time=[ 8:27:29 AM];
        Modified=Yes;
        Version List=;
      PROPERTIES
        Width=8000;
        Height=3190;
      CONTROLS
        { 1000000000;CommandButton;1980;1210;2860;550;
                                                     CaptionML=ENU=Run Vendor Report;
                                                     OnPush=BEGIN
                                                              intFileName := 0;
                                                              REPEAT
        intFileName := intFileName + 1
                                                              UNTIL NOT EXISTS ( FORMAT(intFileName) + '.xml');
                                                              CLEAR(rptTestReport);
                                                              rptTestReport.SAVEASXML(FORMAT(intFileName) + '.xml');
                                                              intTotalPageNo :=rptTestReport.getPageNo;
                                                              IF ERASE( FORMAT(intFileName) + '.xml') THEN BEGIN
                                                              rptTestReport.SetPageNo (intTotalPageNo);
                                                              rptTestReport.RUN;
      CODE
        VAR
          rptTestReport@1000000000 : Report 80000;
          intTotalPageNo@1000000001 : Integer;
          intFileName@1000000002 : Integer;
        BEGIN
        END.
    OBJECT Report 80000 GetPageNoForOrder
      OBJECT-PROPERTIES
        Date=05/31/08;
        Time=[ 8:54:00 AM];
        Modified=Yes;
        Version List=NAVW15.00;
      PROPERTIES
        CaptionML=ENU=Vendor - List;
        OnPreReport=BEGIN
                      VendFilter := Vendor.GETFILTERS;
                      IF NOT bolCalcPageNo  THEN BEGIN
                         intFileName := 0;
                         REPEAT
                         rptTestReport.SetCalcStatus;
                         rptTestReport.SETTABLEVIEW (Vendor);
      DATAITEMS
        { PROPERTIES
            DataItemTable=Table23;
            OnPreDataItem=BEGIN
                            CurrReport.CREATETOTALS("Balance (LCY)");
            OnAfterGetRecord=BEGIN
                               CALCFIELDS("Balance (LCY)");
                               FormatAddr.FormatAddr(
                                 VendAddr,Name,"Name 2",'',Address,"Address 2",
                                 City,"Post Code",County,"Country/Region Code");
            ReqFilterFields=No.,Search Name,Vendor Posting Group;
          SECTIONS
            { PROPERTIES
                SectionType=Header;
                PrintOnEveryPage=Yes;
                SectionWidth=18150;
                SectionHeight=1004;
              CONTROLS
                { 1   ;Label        ;0    ;0    ;7500 ;423  ;FontSize=8;
                                                             FontBold=Yes;
                                                             CaptionML=ENU=Vendor - List }
                { 2   ;TextBox      ;15000;0    ;3150 ;423  ;HorzAlign=Right;
                                                             SourceExpr=FORMAT(TODAY,0,4) }
                { 3   ;TextBox      ;0    ;423  ;7500 ;423  ;SourceExpr=COMPANYNAME }
                { 1000000000;Label  ;15928;450  ;750  ;423  ;ParentControl=1000000001 }
                { 1000000001;TextBox;16678;450  ;450  ;423  ;CaptionML=ENU=Page;
                                                             SourceExpr=CurrReport.PAGENO }
                { 1000000002;Label  ;17128;451  ;485  ;423  ;HorzAlign=Center;
                                                             VertAlign=Center;
                                                             CaptionML=ENU=/ }
                { 1000000003;TextBox;17604;451  ;450  ;423  ;CaptionML=ENU=Page;
                                                             SourceExpr=rptTestReport.getPageNo }
            { PROPERTIES
                SectionType=Header;
                SectionWidth=18150;
                SectionHeight=423;
              CONTROLS
            { PROPERTIES
                SectionType=Header;
                SectionWidth=18150;
                SectionHeight=450;
                OnPreSection=BEGIN
                               CurrReport.SHOWOUTPUT((CurrReport.PAGENO = 1) AND (VendFilter <> ''));
              CONTROLS
                { 8   ;TextBox      ;0    ;0    ;18150;423  ;SourceExpr=Vendor.TABLECAPTION + ': ' + VendFilter }
            { PROPERTIES
                SectionType=Header;
                SectionWidth=18150;
                SectionHeight=1269;
              CONTROLS
                { 9   ;Label        ;0    ;0    ;1500 ;846  ;ParentControl=18;
                                                             VertAlign=Bottom;
                                                             FontBold=Yes;
                                                             MultiLine=Yes }
                { 10  ;Label        ;1650 ;0    ;4500 ;846  ;ParentControl=19;
                                                             VertAlign=Bottom;
                                                             FontBold=Yes;
                                                             MultiLine=Yes }
                { 11  ;Label        ;6300 ;0    ;1500 ;846  ;ParentControl=20;
                                                             VertAlign=Bottom;
                                                             FontBold=Yes;
                                                             MultiLine=Yes }
                { 12  ;Label        ;7950 ;0    ;1500 ;846  ;ParentControl=21;
                                                             VertAlign=Bottom;
                                                             FontBold=Yes;
                                                             MultiLine=Yes }
                { 13  ;Label        ;9600 ;0    ;1500 ;846  ;ParentControl=22;
                                                             VertAlign=Bottom;
                                                             FontBold=Yes;
                                                             MultiLine=Yes }
                { 14  ;Label        ;11250;0    ;1500 ;846  ;ParentControl=23;
                                                             VertAlign=Bottom;
                                                             FontBold=Yes;
                                                             MultiLine=Yes }
                { 15  ;Label        ;12900;0    ;1500 ;846  ;ParentControl=24;
                                                             HorzAlign=Right;
                                                             VertAlign=Bottom;
                                                             FontBold=Yes;
                                                             MultiLine=Yes }
                { 16  ;Label        ;14550;0    ;750  ;846  ;ParentControl=25;
                                                             VertAlign=Bottom;
                                                             FontBold=Yes;
                                                             MultiLine=Yes }
                { 17  ;Label        ;15450;0    ;1800 ;846  ;ParentControl=26;
                                                             HorzAlign=Right;
                                                             VertAlign=Bottom;
                                                             FontBold=Yes;
                                                             MultiLine=Yes }
            { PROPERTIES
                SectionType=Body;
                SectionWidth=18150;
                SectionHeight=4653;
              CONTROLS
                { 18  ;TextBox      ;0    ;0    ;1500 ;423  ;FontBold=Yes;
                                                             SourceExpr="No." }
                { 19  ;TextBox      ;1650 ;0    ;4500 ;423  ;FontBold=Yes;
                                                             CaptionML=ENU=Name and Address;
                                                             SourceExpr=VendAddr[1] }
                { 20  ;TextBox      ;6300 ;0    ;1500 ;423  ;CaptionML=ENU=Vendor Posting Group;
                                                             SourceExpr="Vendor Posting Group" }
                { 21  ;TextBox      ;7950 ;0    ;1500 ;423  ;CaptionML=ENU=Invoice Disc. Code;
                                                             SourceExpr="Invoice Disc. Code" }
                { 22  ;TextBox      ;9600 ;0    ;1500 ;423  ;CaptionML=ENU=Payment Terms Code;
                                                             SourceExpr="Payment Terms Code" }
                { 23  ;TextBox      ;11250;0    ;1500 ;423  ;CaptionML=ENU=Payment Method;
                                                             SourceExpr="Payment Method Code" }
                { 24  ;TextBox      ;12900;0    ;1500 ;423  ;SourceExpr=Priority }
                { 25  ;TextBox      ;14550;0    ;750  ;423  ;CaptionML=ENU=Currency Code;
                                                             SourceExpr="Currency Code" }
                { 26  ;TextBox      ;15450;0    ;1800 ;423  ;SourceExpr="Balance (LCY)" }
                { 27  ;TextBox      ;1650 ;423  ;4500 ;423  ;SourceExpr=VendAddr[2] }
                { 28  ;TextBox      ;1650 ;846  ;4500 ;423  ;SourceExpr=VendAddr[3] }
                { 29  ;TextBox      ;1650 ;1269 ;4500 ;423  ;SourceExpr=VendAddr[4] }
                { 30  ;TextBox      ;1650 ;1692 ;4500 ;423  ;SourceExpr=VendAddr[5] }
                { 31  ;Label        ;1650 ;2961 ;1500 ;423  ;ParentControl=32 }
                { 32  ;TextBox      ;3300 ;2961 ;2850 ;423  ;SourceExpr=Contact }
                { 33  ;Label        ;1650 ;3384 ;1500 ;423  ;ParentControl=34 }
                { 34  ;TextBox      ;3300 ;3384 ;2850 ;423  ;SourceExpr="Phone No." }
                { 37  ;TextBox      ;1650 ;2115 ;4500 ;423  ;SourceExpr=VendAddr[6] }
                { 38  ;TextBox      ;1650 ;2538 ;4500 ;423  ;SourceExpr=VendAddr[7] }
            { PROPERTIES
                SectionType=Footer;
                SectionWidth=18150;
                SectionHeight=476;
                OnPostSection=BEGIN
                                ReportTotalPage := CurrReport.PAGENO;
              CONTROLS
                { 35  ;Label        ;0    ;0    ;2250 ;423  ;FontBold=Yes;
                                                             CaptionML=ENU=Total (LCY) }
                { 36  ;TextBox      ;2300 ;0    ;1800 ;423  ;FontBold=Yes;
      REQUESTFORM
        PROPERTIES
          Width=0;
          Height=110;
          SaveValues=Yes;
        CONTROLS
      CODE
        VAR
          VendFilter@1000 : Text[250];
          VendAddr@1001 : ARRAY [8] OF Text[50];
          FormatAddr@1002 : Codeunit 365;
          ReportTotalPage@1000000000 : Integer;
          rptTestReport@1000000003 : Report 80000;
          intTotalPageNo@1000000002 : Integer;
          intFileName@1000000001 : Integer;
          bolCalcPageNo@1000000004 : Boolean;
        PROCEDURE getPageNo@1000000002() ReturnPage : Integer;
        BEGIN
          ReturnPage :=   ReportTotalPage;
        PROCEDURE SetPageNo@1000000032(PageNumber@1000000000 : Integer);
        BEGIN
           ReportTotalPage := PageNumber;
        PROCEDURE SetCalcStatus@1000000000();
        BEGIN
                 bolCalcPageNo := TRUE;
        BEGIN
        END.
    podollypodolly Member Posts: 84
    I tried to apply this code into the printed purchase order, but find that the button on form called the codeunit, which will execute the report internally.
    Is there any suggestion how to include the code for generating the XML in the PO?
    Cem_KaraerCem_Karaer Member Posts: 281
    If you will use this method inside the same report, namely recursively, you must set a flag to prevent an endless loop. I used the fragment of the code in the OnPreReport section but created endless recursive report creations. So I set a flag, say SavingAsXML by using a function like below:
    SetSavingAsXML(aSavingAsXML : Boolean)
    SavingAsXML := aSavingAsXML;
    And write the following code like below:
    Report - OnPreReport()
    IF NOT SavingAsXML THEN
    BEGIN
      FileName := STRSUBSTNO('Temp_%1_Nakl.xml',FORMAT(CREATEDATETIME(TODAY,TIME),0,'<Day,2><Month,2><Year4><Hour><Minute><Second>'));
      CLEAR(RptNakledilenFis);
      GLEntry.COPYFILTERS("G/L Entry");
      RptNakledilenFis.SETTABLEVIEW(GLEntry);
      RptNakledilenFis.SetSavingAsXML(TRUE);
      IF ERASE(FileName) THEN;
      IF RptNakledilenFis.SAVEASXML(FileName) THEN;
      TotalPageNo := RptNakledilenFis.GetTotalPageNo;
    RptNakledilenFis is a report variable that OnPreReport section belongs to.
    Cem Karaer @ Pargesoft
    Dynamics NAV Developer since 2005
