Print dynamicaly selected columns in bold on report
edited 2009-08-17 in Download section
This is a sample report that shows how you can print selected columns in BOLD based on code. For example if a balance is over 90 days you may want it printed in bold. This code allows multiple columns to be printed without the need for multiple sections.
This fob file is uploaded as support for the thread Dynamically change fields properties in report.
Object is Report 50099.
http://www.mibuso.com/dlinfo.asp?FileID=1117
