London Tube Add-In
edited 2010-06-13 in Download section
London Tube Add-In
This is an Add-In for NAV 2009 SP1 RTC that displays real time information on the status of the lines of the London Underground.
To use it just copy the "London Tube Add-In.dll" file in the Add-ins folder in the RTC intallation folder.
Then insert a new line in table "2000000069" (Client Add-in) as:
Control Add-In Name = LondonTube
Public Key Tocken = 48f3911b65e24838
Or you can use Christian's tool to register Add-Ins in the link below.
Then link the CardPart Page attached to a RoleCenter or to another page to display the Add-in.
If you want more information on add-in please refer to:
http://msdn.microsoft.com/en-us/library/dd983815.aspx
http://blogs.msdn.com/cabeln/archive/20 ... d-ins.aspx
Hope you'll enjoy it!
http://www.mibuso.com/dlinfo.asp?FileID=1170
    London Tube Add-In
    16/03/2010:
    Corrected a bug that was causing the RTC to crash if there was no internet connection.
    BeliasBelias Member Posts: 2,998
    Can we have the source code of the add-in please?
    thanks
    -Mirko-
    My Blog
    London Tube Add-In
    13/06/2010:
    Improved layout, added two new tube lines: DLR and Overground.
    16/03/2010:
