Select Role when logging into NAV 2009 RTC (v2)
edited 2011-04-06 in Download section
This little tool is an addition to the RTC RoleTailored Setup (Profiles & User Personalisation) to be able to select a role when logging into NAV.
It could be useful for:
support-people to give the possibility to set up the system for their specific USERID to select a role when logging into NAV .. to support that specific role at that time.
A complete description of this download if available on my blog: http://dynamicsuser.net/blogs/waldo/arc ... 9-rtc.aspx
http://www.mibuso.com/dlinfo.asp?FileID=1194
  • AdministratorAdministrator Member, Moderator, Administrator Posts: 2,495
    2/12/2010 Update:
    there were some problems when you wanted to personalize pages .. this should be fixed.
    More info: http://dynamicsuser.net/blogs/waldo/arc ... tc-v2.aspx
  • animaconsultinganimaconsulting Member Posts: 10
    This is a great utility - exactly what I was looking for! Thank you for taking the time to upload it so other people can use it and benefit from it!
    Chris
    Chris
    ánima Consulting
    http://animaconsulting.co.uk
  • djkdjkdjkdjk Member Posts: 17
    Hi, community,
    I has tested and used the tool on a DE Database without problems.
    Now I have integrated the tool in our ISV solution. Now I have problems with the tool.
    The page to select the roles didn't appear!
    I have verified that:
    - the "User Profile Selection Active" is true
    - no profile is checked as Default
    - the user has more than one entries in the table "User profiles".
    - the service tier is restarted.
    To find the issue I have add a Message in the trigger "DefaultRoleCenter" before Waldo's change. The Massage didn't appear! :?: :!:
    Did anyone have an (good) idea :idea: where I can find a solution for my issue?
    Many thanks in advance
    Jeannot
