how to I determine the DLL file for an automation
jordi79jordi79 Member Posts: 272
edited 2012-02-10 in Navision e-Commerce
I have an object. It uses automation objects. This object compiles in 1 PC but not in another PC. It says that they are some missing. The message is --> Could not load the selected type library. The automation object that is causing the error is the "CG request client" automation.
Can someone let me know which dll file is this automation loaded from? And can anyone tell which dll file an automation is for from NAV?
    rerun the installation for the client and make sure you have the controls for commerce Gateway checked.
  • jordi79jordi79 Member Posts: 272
    Thanks rashed. But from nav there is no way to find out DLL file for an automation
