It is currently Wed May 22, 2013 7:05 pm
Post new topic Reply to topic  [ 8 posts ]
 Post subject: [Solved] Transformation tool and menu items with action lookup table
PostPosted: Fri Jun 29, 2012 12:05 pm
Country: France (fr)
Hi everyone,
I am trying to transform forms to pages under nav 2009...
I am using the TIF tool...
I noticed that in the menu buttons, the menu items with action lookup table are not imported...
How can I fix that????
 Profile E-mail
 Post subject: Re: Transformation tool and menu items with action lookup ta
PostPosted: Fri Jun 29, 2012 12:19 pm
Country: India (in)
This is not a thing that need to fix, it is feature !!!!.
Such Menu Items always in card Form, and in RTC card forms always called from list form, so there is no need of such menu item so it removed auotmatically by Toolkit, Instead this menuItem, it sets CardFormID in the List form.
_________________
Uday Mer | MS Dynamics NAV Techno-Functional Consultant
 Profile E-mail
PostPosted: Fri Jun 29, 2012 12:25 pm
I don't really understand what you just said...
For example, I have a form with a menu Item (List) that lets me list all the vendors...
How can I access this functionality in the generated page????
 Profile E-mail
PostPosted: Fri Jun 29, 2012 12:30 pm
Country: India (in)
Ya This menu Item is in Vendor Card right ?
But in RTC, first you open this list then double clicking it you are opening Card page.
_________________
 Profile E-mail
PostPosted: Fri Jun 29, 2012 12:43 pm
No, the original form is the card form(Vendor)...
When I click the menu Button and then the menuItem List, it brings me the list of all vendors....
How does it become in RTC????
 Profile E-mail
PostPosted: Fri Jun 29, 2012 12:51 pm
Country: India (in)
In RTC it is reverse scenario, in rtc you are opening Card From List Page,
Have you worked with RTC ?
_________________
 Profile E-mail
PostPosted: Fri Jun 29, 2012 12:55 pm
Now I understand, in RTC it is the opposite...I thought it was the same as in the classic client...
I am new to RTC, that's why...
Thank you for your help :D
 Profile E-mail
PostPosted: Fri Jun 29, 2012 12:56 pm
Country: India (in)
You are welcomed :)
_________________
 Profile E-mail
Users browsing this forum: kdok and 8 guests
