It is currently Thu May 23, 2013 10:01 pm
Post new topic Reply to topic  [ 6 posts ]
 Post subject: NAV 2013 id error
PostPosted: Fri Aug 10, 2012 8:04 pm
Country: Canada (ca)
Hey all,
I have been playing around with NAV 2013, and I accidently renamed the ID for Customer card to 50000. Now when I try to change it back to 21. It gives me the following error message. "You do not have premissions to create the 'Customer Card' Page.
Any ideas how I can bypass this message and set it back to ID 21.
 Profile E-mail
 Post subject: Re: NAV 2013 id error
PostPosted: Fri Aug 10, 2012 9:18 pm
MVP Microsoft Dynamics NAV
Country: United States (us)
Your admin removed that permission probably.
_________________
Rashed.
blog: http://mibuso.com/blogs/ara3n/
 Profile
PostPosted: Fri Aug 10, 2012 9:25 pm
Site Admin
NAV TechDays 2013 attendee
Country: Belgium (be)
If page 21 doesn't exists anymore in your db, import page 21 from a standard Cronus db through a fob-file.Then export page 50000 to a txt-file and change the objectid in the file to 21 using notepad. Now import the txt-file object in your db and compile page 21.
_________________
No support using PM or e-mail - Please use this forum.
Search is your friend || Mark your Topic as SOLVED (= green checkmark) when your question is answered || Read the Forum Rules before making a posting
»»» Mark your calendar: NAV TechDays 2013 - 7 & 8 November 2013 ««« Visit the conference website: www.navtechdays.com
 Profile
PostPosted: Fri Aug 10, 2012 9:40 pm
I am just playing around with the Cronus db in NAV 2013 and get familiar with some of its new features. The chronus database is where i changed the id.
I exported the 50000 id (customer card) to text file and edited it to page 21 and tried importing it. Its giving me the following error message: You do not have permission to create the 'Customer Card' Page.
I created this database few days ago to play around with, I didn't set any admin permissions. How can i create a super user so it will let me import customer card page again...
 Profile E-mail
PostPosted: Fri Aug 10, 2012 9:52 pm
Site Admin
You can't import page 21 in txt-format if it does not exists yet. Download the db from Partnersource again and export page 21 from that db in fob-format. That file can be imported in your db to create page 21 again. And then you can import the txt-file object.
But I'm repeating myself...
_________________
 Profile
PostPosted: Fri Aug 10, 2012 11:17 pm
Oh he renumbered objects not a customer :). You should make a copy of it in 50K range. reimport the object from a fbk.
_________________
Rashed.
 Profile
Users browsing this forum: No registered users and 6 guests
