NAV Finder v2.0.0.28
edited 2013-04-11 in Download section
NAV Finder
This tool helps you find what you are looking for in Dynamics NAV. A typical problem is that you want to search for a text on an invoice line. With this tool you can easily locate both invoices and credit memos with text that matches your search criteria. You can also look for persons, companies, or purchase orders.
Since this is the first release, I would love to have your feedback :-)
http://www.mibuso.com/dlinfo.asp?FileID=1530
  • sebsidsebsid Member Posts: 27
    Guess i got the first bug.
    I get the error message when i start the program.
    Microsoft .NET Framework
    Unhandled exception.
    Hot key is already registered.
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.ComponentModel.Win32Exception (0x80004005): Hot key is already registered
    at  ..()
    at  .​                          ()
    at  .  ​               (  , Keys )
    at  .()
    at  . (Object , EventArgs )
    at System.Windows.Forms.Form.OnShown(EventArgs e)
    at System.Windows.Forms.Form.CallShownEvent()
    at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
    at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
    at System.Threading.ExecutionContext.runTryCode(Object userData)
    at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
    at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
    at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean ignoreSyncCtx)
    at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
    at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
    at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.296 (RTMGDR.030319-2900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
    NavFinder
    Assembly Version: 1.0.0.9
    Win32 Version: 1.0.0.9
    CodeBase: file:///C:/Program%20Files%20(x86)/NAV%20Finder/NavFinder.exe
    Win32 Version: 4.0.30319.1002 built by: RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    Win32 Version: 4.0.30319.1001 built by: RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Xml
    Win32 Version: 4.0.30319.233 built by: RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Security
    Win32 Version: 4.0.30319.1001 (RTMGDR.030319-1000)
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Security/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Security.dll
    System.Configuration
    Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
  • jacobreinholdtjacobreinholdt Member Posts: 9
    Sorry for the trouble. This error happens if you try to launch the program when it is already running.
    A fix has already been released at http://www.morenav.com/download-nav-finder
    I have also tried to describe how you can set up the SQL security to allow the NAV Finder to read from the required NAV tables.
    http://www.morenav.com/nav-finder-doc/security
    I still need all the feedback I can get on the product at this early stage. Please email me at info@morenav.com if you have any.
    Best regards,
    Jacob
  • AdministratorAdministrator Member, Moderator, Administrator Posts: 2,495
    NAV Finder v1.0.0.15
    Find text on lines, comments, persons, phone numbers with spaces and more...
    Design your own queries: http://www.morenav.com/nav-finder-refer ... efinitions
    NEW RTC SUPPORT!!!
    Features
    + Easy to install.
    + Easy to use.
    + Customization of queries.
    + Helps Purchasing/Sales/Manufacturing/Warehouse/Accounting departments save time.
    Standard Queries
    + Find sales invoices and credit memos.
    + Find purchase invoices and credit memos.
    + Find contact persons, companies, and customers.
    + Find phone numbers with or without dots, hyphens, and spaces across contacts, customers, vendors, and employees.
    + Find comments on all types of sales documents.
    + And more...
    More information at: http://www.morenav.com/nav-finder
    Version 2.0.0.31 was released.
    Jacob
