It is currently Mon May 04, 2015 3:03 pm
 Post subject: excel 2007 - how to save files as excel 97
PostPosted: Fri Apr 12, 2013 8:12 am
Country: Czech Republic (cz)
Hello
I have problem with creating excel sheets. I am using excel buffer to fill excel sheet and this code to save prepared excel:
Code: Select all
XlApp.UserControl(TRUE);
XlWrkBk.Close(TRUE,FIleName);
XlApp.Quit;
CLEAR(XlApp);
this code will save prepared excel as default XML format.
our partner who receives excel files has some problem with office 2007 format and requests files in older 97 format.
can anybody tell me, how to change excel format?
I tried to modify my code this way:
Code: Select all
XlWrkBk.SaveAs(FIleName,'43'); /// save as excel 97
XlWrkBk.Close(FALSE);
XlApp.Quit;
CLEAR(XlApp);
but it did not work. number 43 I took from this document: http://msdn.microsoft.com/en-us/library/office/bb241279(v=office.12).aspx and I tried it as number too.
any information will be most appreciated :)
thanks in advance.
_________________
Martin Bokůvka, Skil Olomouc
 Profile E-mail WWW
 Post subject: Re: excel 2007 - how to save files as excel 97
PostPosted: Fri Apr 12, 2013 10:54 pm
MVP Microsoft Dynamics NAV
Country: United States (us)
Perhaps you can introduce them to the compatability pack.
Then they won't have trouble opening newer versions of files.
http://office.microsoft.com/en-us/suppo ... 68676.aspx
_________________
Harry Ruiz
http://www.BiloBeauty.com
http://www.autismspeaks.org
 Profile E-mail WWW
PostPosted: Mon Apr 15, 2013 7:11 am
yes, I know...
but this is not sending office files to customer with human on other end - it is DB Schenker WMS which processes XLS files automaticaly :(
at this time we created small VB script which is called after XLSX file creation, but I do not like this workaround
_________________
 Profile E-mail WWW
PostPosted: Mon Apr 15, 2013 8:46 am
I am trying to use this vbscript as workaround...
If Iľl run it from saved file, then conversion is performed. but from NAV, execution fails...
Code: Select all
_autVBScript.Language := 'VBScript';
_charCR := 13;
_txtCR := '';
_txtCR[1] := 13;
_txtCode := _txtCode + 'dim objShell' + _txtCR;
_txtCode := _txtCode + 'Set objShell = CreateObject("Wscript.Shell")' + _txtCR;
_txtCode := _txtCode + 'Set objExcel = CreateObject("Excel.Application" )' + _txtCR;
_txtCode := _txtCode + 'Set objWorkbook = objExcel.Workbooks.Open("' +
            _txtXLSXFile + '")' + _txtCR;
_txtCode := _txtCode + 'objExcel.Application.Visible = False' + _txtCR;
_txtCode := _txtCode + 'objExcel.Application.DisplayAlerts = False' + _txtCR;
_txtCode := _txtCode + 'objExcel.ActiveWorkbook.SaveAs ("' +
            COPYSTR(_txtXLSXFile,1,STRLEN(_txtXLSXFile) - 1) + '"), 56' + _txtCR;
_txtCode := _txtCode + 'objExcel.ActiveWorkbook.Close' + _txtCR;
_txtCode := _txtCode + 'objExcel.Application.DisplayAlerts = True' + _txtCR;
_txtCode := _txtCode + 'objExcel.Application.Quit' + _txtCR;
_txtCode := _txtCode + 'WScript.Quit' + _txtCR;
_autVBScript.AddCode(_txtCode);
_autVBScript.ExecuteStatement('OpenFile()' + _txtCR);
for error message please see attached file.
any help will be welcomed
_________________
 Profile E-mail WWW
Users browsing this forum: No registered users and 19 guests
