It is currently Mon Jan 26, 2015 1:27 pm
Post new topic Reply to topic  [ 6 posts ]
 Post subject: RTC Report Issue
PostPosted: Fri Apr 12, 2013 2:42 pm
Country: Serbia (rs)
Can anyone explain this strange behaviour... ](*,)
I'm working some customization on report 206 ( NAV v6 ), and I just need to move some fields in header of the document to the right:
On the picture above, I want to move textboxes in rectangle "2" to the right. And here is the result after I done this:
I'm not trying to find solution for this, but explanation why this occurs. Is this some kind of bug, or am I doing something wrong?
 Profile E-mail
 Post subject: Re: RTC Report Issue
PostPosted: Fri Apr 12, 2013 6:04 pm
Country: India (in)
I guess this is due to Auto Grow set to true for Code.GetData(13,4) , Code.GetData(19,4) & Code.GetData(21,4).
Try by resting the Auto Grow to False.
Let me know if any issues.
_________________
Thanks & Regards,
Saurav Dhyani
http://saurav-nav.blogspot.in
 Profile E-mail
PostPosted: Mon Apr 15, 2013 8:12 am
Hi postsaurav,
Thanks for replay. If you are talking about 'CanGrow' and 'CanShrink' properties it have been set to false already. Have any other idea?
 Profile E-mail
PostPosted: Mon Apr 15, 2013 9:21 pm
MVP Microsoft Dynamics NAV
NAV TechDays 2014 attendee
Country: Denmark (dk)
As I see it, you are showing the reports in Print Preview and not in Print Layout.
Print Preview is dynamic and we have little control on how the report will look. Report Viewer will try to squeeze as much as possible on the page in Print Preview, so Print Preview is not an representation of how this report will look when printed.
In Print Layout we have full control on how the report will look and we can see how it will appear on paper when printed.
So could we have a look at the how the report looks in Print Layout?
/Claus Lundstrøm
_________________
Claus Lundstrøm | MVP | Senior Product Manager | Continia.com
I'm blogging here:http://mibuso.com/blogs/clausl and used to blog here: http://blogs.msdn.com/nav
I'm also offering RDLC Report Training, ping me if you are interested. 600+ NAV developers have now been at my training
 Profile
PostPosted: Thu Apr 18, 2013 12:43 pm
clausl,
Print Layot is disabled for that report, but resulting document that is actually printed on paper is the same as Print Preview that I have posted here.
 Profile E-mail
PostPosted: Thu Apr 18, 2013 8:59 pm
OK, but Print Preview is never a real representation of how the report looks on paper, so it would make more sense to print PDF, then take a screendump and show us that.
I have spend hours and hours trying to get elements to print correctly in the header. Each time I end up placing rectangle around the elements I have issues with.
So maybe you could try to put a rectangle around 1 and 2? This is a clear bug in Visual Studio in my eyes that we are required to that.
For you 3rd issue I would just put the 2 fields together in 1 and seperate the 2 fields with this & " " & in the expression.
/Claus Lundstrøm
_________________
 Profile
Users browsing this forum: kriki and 10 guests
