Citrix colours Navision 2009
Toddy_BoyToddy_Boy Member Posts: 230
Dynamics 2009 classic client on Citrix Terminal Servers Windows 2008 R2
I have a strange situation where Navision clients in Citrix are showing different clients. We've tried deleting zup files with no joy, it seems to force 16 bit colours on the terminal servers for some users and the better quality 32 bit (or better) client for others
Any ideas?
Life is for enjoying ... if you find yourself frowning you're doing something wrong
  • FDickschatFDickschat Member Posts: 380
    This is the difference between a Windows Aero design and a Windows basic design.
    On W7 you can try it yourself - Just change the design and watch how NAV changes.
    In a remote session this is controlled by 3 things:
    - Is Aero configured at all on the TS?
    - Group policies
    - a quality setting in the remote desktop client when connecting (this is true for RDP. If it is the same for Citrix I am not sure).
    Frank Dickschat
    FD Consulting
  • Toddy_BoyToddy_Boy Member Posts: 230
    Thanks for the pointers
    Apparently the Aero is turned on and the Group Policies are the same for individuals.
    It's odd that certain users always get the non-aero version and vice versa
    If you have any further ideas then please let me know
  • rocatisrocatis Member Posts: 163
    There's a hotfix relating to the Aero colour scheme.
    Problem is, my client just installed this, and the colours went from bad to worse.
    From what I can gather, the only option is to disable Aero?
    Brian Rocatis
    Senior NAV Developer
    Elbek & Vejrup
