item ledger entries sort by newest first
drakosesdrakoses Member Posts: 2
Good afternoon
I am new user of NAVISION 2013 (in the past I used to use AXAPTA).
When I go to an item and then to item ledger entries I configure NAV to sort the list as "sort descending" (From Z to A). But to go to the first entry I must go to the top of the list (Ctrl+home)
How can I configuro NAV to goes directly to the newest entry?
Thanks in advance
    awarnawarn Member Posts: 261
    How about:
    1 - Find the Entry No. field. Click on it to sort Descending.
    2 - Press Item Ledger Entries (top left, blue text), and Save View as, call your view Ledgers by Entry No.
    3 - This view is now saved in your lists on the left hand side.
