Upgrade from Nav2009 to Nav2013R2 - Windows Users handled?
jensthomsenjensthomsen Member Posts: 173
edited 2014-08-26 in NAV Three Tier
Hi. Will windows users created in a Nav2009 database (table 2000000054 and 2000000002) be converted to windows users in nav2013R2 (table 2000000120) by use of the standard upgrade toolkit? And how? Do we have to make the upgrade in the "real environment" or is it possible to to the upgrade locally?
    Not sure, did the update locally but redid the users/roles too because a lot has changed
    Yes there is code in upgrade toolkit to upgrade the windows users. I didn't look in detail if AD was required.
