Nav 2013R2 Outlook Integration in the cloud
KyhnelKyhnel Member Posts: 5
edited 2014-09-18 in NAV Three Tier
Do anyone know if you can setup outlook integration if you have Navision in the cloud and your exchange server on your local domain.
i can find allot of specification on how to set it up when you are on the same domain but if u are having Navision hosted in the cloud you logon to the host and i guess you use the hosts AD which probably will not work to connect to your local domain.
