Export flowfields to Excel connecting from SQL Server
ReedbergReedberg Member Posts: 68
Hi, experts,
I need to export Item Ledger Entry table into Excel. I export data using "Connect from SQL" function in Excel. It works fine but it does not export the content of flowfields, namely there is no fields "Amount" and "Adjusted Cost" in the resulting Excel file.
I understand that "Amount" and "Adjust Cost" are actually views on SQL server and thus I can't simply export them. But may be there is a simple way to export the content of flowfields using "Connect from SQL" function anyway?
Thanks in advance!
