Disable option in a filter field
poppinspoppins Member Posts: 647
edited 2015-01-29 in NAV Three Tier
Hi everyone,
I have a request and I don't know if it is possible :oops:
When running a report, the user has to choose one or many values from a request filter field of type option.For example we have Document type as request filter field and Document type is an option field in table 36 with values Quote,Order,Invoice,Credit Memo,Blanket Order,Return Order
Is it possible to disable some of those options, I mean when the user drops down to select values, some of them are not selectable(he can't click on them)?
Thanks in advance :mrgreen:
  • Luc_VanDyckLuc_VanDyck Member, Moderator, Administrator Posts: 3,633
    No that's not possible. You'll need to add code in the OnPreReport-trigger to display an error message when a unwanted value is selected.
