navision ports
nsralfakeehnsralfakeeh Member Posts: 2
Hi guys
I need your help
I have navision dynamics 2009
i installed in one store 2 pos i connected with the first one by default port of navision
but the other one i can not connect with it every time i open port server not listening
please help
  • vremeni4vremeni4 Member Posts: 323
    I assume you are refering to NAV 2009 RTC version.
    When you install two NAV Server services they have to run on different ports.
    Please use the configuration file of the NAV Server Service to change the port numbers.
    for example the first service cna run on the port 7046 th second one can be on the port 7146.
    I hope this helps
