Search bar - sort searched items
TomigsTomigs Member Posts: 85
edited 2015-04-30 in NAV Three Tier
Hi experts,
I wonder if there is a way of modifying the order in which the items appear in the search bar (RTC) when doing a search.
For example if you type "G/L" in the search bar, the proposed results are first "G/L budgets" and in second position "G/L entries". I would like for example to switch those two items in the search (though it sounds la sci-fi to me).
By the way, what criteria does it use? I guess it has to do with the order of the items in the menusuite...
Thank you,
Tomas
    Hi again,
    I don't know if there is a better way to manage it, but I have checked that the search just follows the order of the menusuite in the development environment. So, if say, in the Purchases department/ Planning folder I have two items [Purchases offer] and [Purchases Order], in the RTC search bar, will appear in the same order in which they are in the menusuite in the development client. So at least you can play with this order. It is enough for my requirements right now.
    Thanks all,
    Tomigs.
