NAV classic client response time
isaksigisaksig Member Posts: 10
edited 2015-04-24 in NAV Three Tier
Hi there,
I was hoping if anyone knows a answer to my question, we have a customer that is setting up an terminal server for NAV and they are finding a practical location for hosting the server.
They are concerned about the response time for the SQL server to get back to the NAV client. So my question is how many milliseconds can the NAV Client wait for response from the SQL server until the user gets an error?
He is currently running version 6.0.33319 and is using the classic client.
Isak.
    bbrownbbrown Member Posts: 3,268
    The terminal server (Remote Desktop Host Services) should be on the same local network as the SQL Server. Thus, I'd say, the question becomes irrelevant.
