Assembly sales order
BlackdiamondBlackdiamond Member Posts: 29
edited 2015-04-28 in NAV Three Tier
I have been searching and not found it yet. Sorry if it has been answer before, then please guide me to the answer.
My question:
#1 When you create a Sales order,
Fasttab lines, enter a number in field "Quantity", why does it not auto populate in field "Qty. to Assemble to Order". I have seen in different videos that is does auto populate. How is that possible? Do I need to activate this?
#2 Sometimes the field "Reserved Quantity" get filled auto and sometimes it is blank. Where do you customize this setup?
    rico1931rico1931 Member Posts: 295
    1) Qty to Assemble only populates if the item card for the item is set to Assembly and there is a Assembly BOM for it.
    2) Same thing in the Item card. Under the Planning fast tab there is a "Reserve" field you need to change to Never
    -rico1931
