OLE Controll Error Dynamics NAV
shanabeywicremashanabeywicrema Member Posts: 53
Dear Experts,
I am using Member Management in LS Retails. When I enter correct active member card and press ok I am getting following error but if I enter wrong cord number its showing standard error, I am using Dynamics NAV LS 2009 and Toolbox 6.4
Here is the error
This message is for C/AL programmers:
Could not create an instance of the OLE control or Automation server identified by
GUID={DD3D91CA-1FD2-4CDF-8958-03C980039769} 1.0:{4632654B-DAEC-4087-A7E7-F97308E24BEB}:Unknown Automation Server.Unknown Class.
Check that the OLE control or Automation server is correctly installed and registered.
OK
Thank
    absolutelyfreewebabsolutelyfreeweb Member Posts: 104
    NAV won't throw an error if you don't use a missing external object.
    When you enter correct info, it tries to find a dll that is missing on your machine.
    (re)install the dlls for your credit card solution.
