Automation to .NET - XMLHttpConn Component
martinhocosta88martinhocosta88 Member Posts: 27
edited 2015-05-26 in NAV Three Tier
A partner is trying to post an invoice via web service and is getting an error because of an automation component: XMLHttpConn in a specific codeunit. I'm wondering about remaking it's implementation in .NET since it could solve this problem and the webclient limitations over automation also.
I thought about System.Xml.XmlDocument but the problem is occurring in the following code:
IF ISCLEAR(XMLHttpConn) THEN
CREATE(XMLHttpConn,TRUE,TRUE);
So I would like to know if anyone know a .net component that could replace XMLHttpConn in the connection scope.
thanks in advance.
    NixPtNixPt Member Posts: 19
    Boas espero que ajude, Hope this helps
    Name	DataType	Subtype	Length
    XmlHttpRequest_DotNet	DotNet	'System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.Net.HttpWebRequest
    XmlHttpResponse_DotNet	DotNet	'System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.Net.HttpWebResponse
    XmlDomElem_Dotnet	DotNet	'System.Xml, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.Xml.XmlElement
    xmlProcessingInst	DotNet	'System.Xml, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.Xml.XmlProcessingInstruction
    NewChild	DotNet	'System.Xml, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.Xml.XmlNode
    CurrNode1	DotNet	'System.Xml, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.Xml.XmlNode
    CurrNode2	DotNet	'System.Xml, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.Xml.XmlNode
    CurrNode3	DotNet	'System.Xml, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.Xml.XmlNode
    CurrNode4	DotNet	'System.Xml, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.Xml.XmlNode
    ______	Integer
    MemoryStream	DotNet	'mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.IO.MemoryStream
    Encoding	DotNet	'mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.Text.Encoding
    Bytes	DotNet	'mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'.System.Array
    TempBlob	Record	TempBlob
    vInStream	InStream
    vBigText	BigText
    vOutStream	OutStream
    //Creates SOAP Connection//
    XmlHttpRequest_DotNet := XmlHttpRequest_DotNet.Create('https://onlinetools.ups.com/webservices/TimeInTransit');
    XmlHttpRequest_DotNet.ContentType('application/xml;charset=utf-8');
    XmlHttpRequest_DotNet.KeepAlive(TRUE);
    XmlHttpRequest_DotNet.Method('POST');
    XmlHttpRequest_DotNet.ReadWriteTimeout(5000);
    XmlHttpRequest_DotNet.Timeout(5000);
    ///STREAM REQUEST///
    TempBlob.Blob.CREATEOUTSTREAM(vOutStream);
    XmlDomDoc_DotNet.Save(vOutStream);
    CLEAR(INSTREAM);
    MemoryStream := MemoryStream.MemoryStream();
    TempBlob.Blob.CREATEINSTREAM(vInStream);
    vBigText.READ(vInStream);
    Bytes := Encoding.UTF8.GetBytes(vBigText);
    XmlHttpRequest_DotNet.ContentLength(Bytes.Length);
    MemoryStream := XmlHttpRequest_DotNet.GetRequestStream;
    MemoryStream.Write(Bytes,0,Bytes.Length);
    MemoryStream.Close;
    MemoryStream.Dispose;
    //Get Response
    XmlHttpResponse_DotNet := XmlHttpRequest_DotNet.GetResponse;
    XmlDomDoc_DotNet.Load(XmlHttpResponse_DotNet.GetResponseStream);
    XmlHttpResponse_DotNet.Close;
    XmlDomNoneList_DotNet := XmlDomDoc_DotNet.GetElementsByTagName('common:Code');
    XmlDomNode_DotNet := XmlDomNoneList_DotNet.Item(0);
    XmlDomDoc_DotNet.Save('C:\UPS_LeadTimes_Response.xml');
    Dan_KDan_K Member Posts: 3
    thanks in advance.
    Yes you can pretty much directly replace the automations using .NET. We were using MSXML03 in our Classic product and have rewritten everthing in DotNet using the System.Xml library.
    If you're using DotNet variables you'll need to initialise the variable slightly differently.
    For XMLDocument you can use the constructor e.g;
    XMLDoc := XMLDoc.XmlDocument();
    You can check to see if the DotNet variable has been initialised using ISNULL.
    e.g. IF ISNULL(XMLDoc) THEN...
    Have a look at System.Net.HttpWebRequest for your XMLHttpConn variable.
    Thank you both. That actually helped
