Recommandation for a Robust NAV Dimension Editor
Tarek_DemiatiTarek_Demiati Member Posts: 112
edited 2015-06-02 in General Chat
Who could recommend me a rock robust Dynamics NAV add on that allow end users to Modify / Created posted dimensions throughout NAV (Documents, Ledgers, Customer/Vendor/Job/item records)
I've bumped into Dimension Manager : http://www.dynamicsnavaddons.com/sites/ ... gement.pdf
Is there any other alternative ?
    bbrownbbrown Member Posts: 3,268
    I guess basic accounting fundamentals don't mean anything these days.
    I guess you could make a case for changing dimensions that are only used for analysis - though a dimension editor would not know the difference.
    If people are really going to do it, then using a tool that changes it in all places would be better than hand editing or custom programming.
    Upgrades from prior to NAV 2013 to NAV 2013 and above are lots of fun when people have been playing around with dimensions.
    That addon looks good. What is the price?
    BTW: there is a dimension editor for classic in the download section.
