Maximum number of NAV tenants in a single tenant environment
yasithyasith Member Posts: 30
edited 2015-08-05 in NAV Three Tier
Hi All,
I'm having a NAV 2015 multi tenant environment and so far there are 21 tenants in that multi tenant environment.
Does anyone know the maximum number of tenant which can have in a single multi tenant environment?
Cheers!
Yasith
    I don't believe there is a fixed limit. However I think there will be a practical limit based on your infrastructure and the loads of each tenant. Remember the tenant databases do not all need to be on the same SQL instance. So the ability to scale up and out could potentially create some sizable environments. Perhaps Microsoft will do a White Paper. :)
  • yasithyasith Member Posts: 30
    Thank you for your respond.... :thumbsup:
