Rapid Start - Item Identifier
spenaspena Member Posts: 45
edited 2015-09-01 in Navision Attain
I'm trying to import into the Item Identifier table (7704). I created an excel export template using the Configuration Template. I populated the template with the "Code" and the Item No.
The file imports just fine. However, when I apply the data, nothing imports. I get an error stating:
"Item No. must have a value in Item Identifier: Code = xxx. It cannot be zero or empty. Field caption - Code
Where xxx is my upc number. My item no. and code are 100% filled out.
I don't know what is wrong. I use Rapid Start all the time without issues, but for some reason, I can't import the Item Identifiers.
Has anyone seen this before? I've tried importing using a Configuration Worksheet and as part of a package with the item table. I can hand enter data just fine.
Steve
