Adding a Field to a Report from a Different Table
navdarrennavdarren Member Posts: 3
I have a report called Quote Analysis that's made up of two DataItems: "Sales Header" and "Sales Line".
The report shows information such as "Quote Number", "Customer Name", "Quote Date" etc.
I'd like to add a new column to the report called "Branch", which needs to come from the Customer table from a field also called "Branch", but I can't work out how to do this.
I've tried adding a new Variable within "C/AL Globals" called "CustomerBranch" and set the DataType to "Record" and the Subtype to "Customer" table. I then added a new TextBox to the report, and set the SourceExpr as "CustomerBranch.Branch". When I run the report the Branch field is empty; I presume I'm missing some code which will show the data.
I'd really appreciate any help with this.
I'm using NAV 5.0 SP1.
Many thanks.
    You need to add a read:
    CustomerBranch.GET("Sell-to Customer No.") to the code in the sales header data item.
    You should also download or buy some manuals / books on C/AL programming.
    The original training manual will lead you through all the basic concepts.
    Perfect, thank you!
