Select Sales Report when printing [Navision]
edited 2005-09-15 in Download section
This little modification allows you to choose between different reports when printing a sales quote, order etc.
Reports are used from the report selections
This fob file is uploaded as support for the thread Choosing Reports from a Form.
Objects are Form 50000 and Codeunit 229.
http://www.mibuso.com/dlinfo.asp?FileID=513
    Michael_SchumacherMichael_Schumacher Member Posts: 81
    One Warning!
    be careful using this CodeUnit 229, it differs in the Versions of Navision.
    As I remember this 229 in the fob is of Version 3.7.
    in 4.0 there are extensions made for german language area (DACH)
    take a look at the version string in Object designer before....
    e.g. here it is NAVW13.60,NAVDACH4.00
    regards,
    Michael Schumacher
    oh, what day is it? Backup day. OK, let's dump all data to /dev/nul ;-)
    All Navision objects that are available for download on this site, are (or should be) developed using the Worldwide version of Navision. This to ensure that no localizations are used, and that everyone can use the objects. If changes are made to existing objects, and one would like to use the download on a country-specific database, one should always check if these objects are localized.
    In the NL database (The Netherlands) there are no customisations in this codeunit.
    I used the NL database to create this mod and removed the NLD language layer before sending it to Luc.
    edited 2005-09-15
    OK, I just wanted to bring that in attention, because I realized it in the last possible moment in the version columns of the import worksheet ;-)
    If s.o. doesn't realize it early enough, he will get problems especially when he uses the backup method I mention in my signature :mrgreen:
    regards,
    Michael Schumacher
    That is why the version column exists :D
    yes, but sometimes I realized that import worksheet is not always requested even if version info in the columns differ.
    regards,
    Michael Schumacher
