activeTAPI-DyNav v4.02
edited 2007-11-21 in Download section
activeTAPI-NAVI v1.20
activeTAPI-NAVI integrates Microsoft Navision 3.x (and higher) with TAPI-Telephony.
activeTAPI-Navi is a COM-DLL that brings the Windows-TAPI Telephony Services into Navision. activeTAPI-Navi also includes Navision sample objects that can be used as an out-of-the-box solution. Since the Navision objects are not locked you can easily build your own telephony solution for you customer's requirements.
International 30-days trial version.
http://www.mibuso.com/dlinfo.asp?FileID=525
    activeTAPI-DyNav integrates Microsoft Navision 3.7 (and higher) with TAPI-Telephony.
    activeTAPI-DyNav is a COM-DLL that brings the Windows-TAPI Telephony Services into Navision. activeTAPI-DyNav also includes objects (FOBs) for Micosoft Dynamics NAV that can be used as an out-of-the-box solution. Since the Micosoft Dynamics NAV objects are not locked you can easily build your own telephony solution for your customers.
