ERROR While running RTC
chandrurecchandrurec Member Posts: 560
edited 2011-01-13 in NAV Three Tier
Hi all,
I have installed configured 4 domain users in server 192.168.0.242 with windows authentication and granted administrative rights with the following names.
Stock1
Stock2
Stock3
Stock4
I can able to login through Stock1 and can run RTC. But when I login through Stock2,Stock3,Stock4 I am getting the error "Cannot connect the sql server".If anyone knows the solution for this error, Kindly let me know.
Thanks in advance.
Chandru.
    manishkutarmanishkutar Member Posts: 19
    Have you tried for configuring roles in SQL server??
    I mean have you assigned roles to Stock2,3 and 4??
    Just check it..
    It may solve....
    Manish Kutar
    Technical Consultant
    MSDN NAV
    Manish Kutar,
    Senior Technical Consultant
    manishkutar@gmail.com
    raveendran.sraveendran.s Member Posts: 119
    Check whether u synchronized the roles or not
    Raveendran.BS
    kinekine Member Posts: 12,562
    Which license? Check the event log on the service tier and on the client for more info about the problem.
    krikikriki Member, Moderator Posts: 9,090
    [Topic moved from 'NAV/Navision Classic Client' forum to 'NAV Three Tier' forum]
